It is currently Wed Aug 06, 2025 1:35 pm
 Post subject: sanded thru
PostPosted: Fri May 01, 2009 6:57 pm
First name: Jeff
Last Name: Hewitt
Zip/Postal Code: 37312
I probably know the answer I'll get but, how would some of you fix a small sand thru?
There are two spots I went thru to the wood. The guitar is polished up and I'd hate to have to start over. The finish is EM6000.
Jeff
 Post subject: Re: sanded thru
PostPosted: Fri May 01, 2009 7:22 pm
First name: David
Last Name: Engel
City: Stanwood
I did the same thing earlier this year. I cut out and bent to match a piece of the same material, epoxied it on the inside and pressed on. Anyone looking inside the box will see it, but... it's a repair, so what. Your still probably going to have to do some finish work again.
God, Family, Carreer
PostPosted: Fri May 01, 2009 8:09 pm
When re-applying more of the EM6000, you have to sand the area down to 320. Not the entire side mind you, but for a couple of inches around the sand through area, than touch up. Let it cure again for 1 week and level the area LIGHTLY and buff again.
PostPosted: Fri May 01, 2009 10:18 pm
Last Name: Cox
Welcome to the Holey-finish club.
You are in good company.
I am always amazed when John Hall talks about shooting 0.025"-0.030" worth of finish on.... to get a 0.006" finished thickness..... but it seems about right after levelling and all the other finishing... It just seems to take about 3x as much finish as seems sensible... I look at it and say "Holy Cow -- 40 lbs of finish...." and *Still* sand through because it wasn't thick enough......
Good luck
PostPosted: Sat May 02, 2009 10:26 am
After doing it one way for about 30 guitars (just shoot lac until it looks like there is enough) and then sanding out to buff, and giong thru about 1 in 4 .... I started doing a total 400 grit flat sand half way thru - if you happen to sand thru now, at least you know you are shooting more and can double shoot any trouble spots. The finishes have improved (with almost no rub thrus) ever since.
PostPosted: Sat May 02, 2009 8:17 pm
First name: Trevor
Last Name: Lewis
City: Crownsville
Zip/Postal Code: 21032
I just did the same thing, with the same finish...!
As was mentioned, rough up the area with 320 and then reshoot over the area to build enough thickness to level it out again. Then, do not wet sand....dry sand only...! I got some strange foggy lines when I attempted to wet sand a finish that was "touched up".
Now that I've got this stuff figured out, I'm looking for my next EM6000 experience to go much smoother...!
Good luck,
Trev
http://www.PeakeGuitars.com
PostPosted: Sat May 02, 2009 8:39 pm
Whoo, I could write a book on sand throughs after this last build. The repairs wouldn't have been so challenging had I not gone through the shellac wash coat underneath. Now that's a challenge -- matching the shade of shellac to the surrounding area already under finish. I learned a huge lesson in all of that -- to be very generous when applying the finish. I also learned the importance of achieving as level a sprayed surface as possible, to minimize sanding and the possibility of sanding through in the first place.
I've pretty much decided to just farm out finishes for commissioned guitars, at least till I get the process dialed in much better.
Ken
Mountain Song Guitars www.mountainsongguitars.com
Users browsing this forum: Colin North, mcgr40, Melt in the Sun, ptourin and 17 guests
cron
